best cam for 383?
Old Jun 28, 2003 | 04:45 PM
project j's Avatar
Car: black irocz
Engine: 305tpi
best cam for 383?
I will be putting a 383 in my 89 IROCZ here in the next few months. I plan on converting the pre-87 block to a roller setup. here is what is going into the constructon of the block:
Eagle H-Beam 6" rods
KB domed hypertuectic pistons 11:1 cr w/ 64cc heads
AFR 195 cc heads with hyper rev kit
Holley Stealth Ram intake
58mm throttle body
Full length headers with X-pipe and flowmater 2chamber delta flows
I really want this motor to make aot of mid to upper rpm power. I will be driving this car occasionaly from work and back and cruising street on the weekends when I can I want this motor to pull to 6000 rpm too. Thank you
Old Jun 29, 2003 | 01:47 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Give Comp Cams or Crane Cams a call... they can give you a much better answer than any of us can.
Jorlain
Oct 8, 2015 01:57 AM
abray1
Sep 10, 2015 04:53 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
