Help me out
Old Oct 1, 2000 | 09:40 PM
CamaroVroom's Avatar
Help me out
Ok lets make this short and sweet. I have an 88 RS and i'm loosin antifreeze fluid but its not the head gasket and the radiator is reading 100% wassup with that??
Old Oct 1, 2000 | 10:29 PM
MIKES 88GTA's Avatar
If the water pump is going out then water will drip out of the little hole under the pulley and evaporate from engine heat before you even get to see it.If that's not it then there's a pin hole somewhere in a hose and it's spurting out where you can't see it.If it's not either one of those then some one with more knowledge better take over from here.
Old Oct 1, 2000 | 10:52 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Check the pass. side floor, under the mat if you have them.
Get it pressure checked, it'll show.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
