Oil capacity
Old Jun 29, 2003 | 01:23 PM
Uwe 1985-IROC's Avatar
Car: 1985 IROC-Z28
Engine: TPI 350
Transmission: TH700-R4
Oil capacity
Hallo to everybody !
I just swapped a 305 ( build in 1978 ) for a 350 ( build in 1987 ). I purchased the rebuild block without an oil-dipstick-tube. I installed one from Mr.Gasket ( MRG-6237 ). Now my problem is, I had to refill about 8 liters of oil since I saw anything on the dipstick. That seem a lot to much ( aren´t 5 liters normal ? ). Perhaps I have the wrong dipstick-tube installed ?
Thanks, Uwe
Old Jun 29, 2003 | 02:46 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
5 quarts for a SBC w/standard pan. You'll have to convert for liters...I'm "metrically challenged"
Old Jun 29, 2003 | 02:53 PM
ChaosRanger's Avatar
Car: 1984 F41 T-Top
Transmission: 5 speed
1 QT (946 mL)
V8
Oil Change Only 3.8L (4 QT)
Oil & Filter 4.7L (5 QT)
you may have a wrong size dipstick
Old Jun 30, 2003 | 10:28 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I only put 4 quarts in my 88 formula and it reads about a 1/4 quart over. There is a slight dent in the bottom of the pan but I don't think that should really make a full 1.25 quart difference. Unless of course there's a difference between an 88 305 pan / 350 pan and the 350 block I put in the car.
Old Jun 30, 2003 | 12:57 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
You have something REALLY wrong.
5 fluid quarts (US) is equal to 4.73 liters.
I would only put about 4 to 4.25 liters in WITH the oil filter on. It's better to be a little low than too much.
Old Jul 7, 2003 | 02:36 PM
Car: 1985 IROC-Z28
Engine: TPI 350
Okay, I checked it out, and I had definitely installed a wrong dipstick. No I filled in about 5 quarts a it reads right. Now my problem is, that I have some oil-leaks. One is right in front of the engine ( between the oilpan and the timing-cover ) and the other one above the starter. Could the high pressure due to the overfilling shot my oilpan-gasket or is there another place I can look ? - I read something about a missing front bolt (the upper one on the passengerside of the waterpump ), is this relevant for a 1989-engine, too ? ( 350, casting-number 10054727).
Thanks in advance,
Uwe
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
Numbah-1
Oct 2, 2015 08:27 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
