full MSD from scratch
Old Jun 29, 2003 | 10:32 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
ok i got the 6AL, 8361 distributor and coil...
i have the power leads hooked up, the orange and black to the coil..the distributor im using uses the tach output on the back (the purple and green wires)..that go directly to the distributor, so the white wire isnt used..
i get it all hoked up and i have the red wire that gores to the ignition switch...in the manuel it says to hook this wire to the old coil wire...
im goin to a carb setup so the ecm wont have any power to that wire right?
i followed a fat pink wire from what i assume was the coil, back the relays by the brake booster...
how would i hook that up?...
i need to run a wire to the starter and alternator to right>?
thanks guys
Rob
(edit)...i posted this in the wrong forum..wont happen again
Old Jun 30, 2003 | 09:41 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
comon guys this should be an easy one...
Old Jul 2, 2003 | 11:13 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
i guess noone knows how to wire in an ignition...
learn somethin new everyday
Old Jul 3, 2003 | 03:14 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
try a search... this has been gone over many times.. lemmie see if i can find ya ne..
Old Jul 4, 2003 | 11:17 AM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
i tried doing a search
i searched for
MSD ignition wiring
MSD 6AL wiring
ignition wiring
about about 5 other derivitives..
i wouldnt of posted the message if i hadnt of tried to search, it really works..just not in my particular case
morrow
Jan 13, 2024 12:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Stryker412
Sep 20, 2015 06:59 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
