4th gen drive shaft in a 3rd gen
The Aluminum 1LE, LT1 and LS1 dr shafts are all the same length and are interchangeable on 3rd gen cars with a 5sp & 700R4.
Early 82 transmissions may be a another question if they will fit??
Check the length before buying to be safe. Summit's Catalog is not always correct, if you get my drift.
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Yes, but the LS1s are much bigger in diameter, so you're going to have to check for exhaust/torque arm clearance too.
Not only that, the LS1 shafts seem weaker for some reason. I've seen a couple peeled open.
Car: `86 SS / `87 SS
NO
the 200-4R driveshafts are approximately 2.92" longer than 700/4L60/T5/T56 driveshafts from 3rd & 4th gens.
sorry to yell. Just tired of this question and then people ignoring the fact of what transmission the car has.
LT1=2 3/4 dia
LS1=3 dia
What is so weak about the LS1 Shaft is the LS1 engine.
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
Originally posted by DJP87Z28
1LE=2 3/4 dia
LT1=3 dia
LS1=3 dia
1LE=2 3/4 dia
LT1=3 dia
LS1=3 dia
Guest
Posts: n/a
Originally posted by jmd
NO
NO
jmd is right (as usual). the 200 4r driveshaft is about 3 inches longer.can a machine shop make it longer?
The tubing cannot be lengthened. The full length of the tubing can be replaced with a new tube.
Good luck w/ your driveshaft project.
I just got my steel 69 firebird shaft balanced and the rear joint replaced.
-Matthew
I just got my steel 69 firebird shaft balanced and the rear joint replaced.-Matthew
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
