how to find out exhaust pipe size
Old Jun 29, 2003 | 10:33 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
How can i find out what size my exhaust pipes are so i can get the right exhuast tips.
I have a flow master muffler with the dual exhuast coming out from the one muffler. On a 86 camaro Z28
I don't know if it is 2 1/4 or 2 1/2
how can i find out???
Old Jun 29, 2003 | 10:35 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Measure the diameter of the pipes with a tape measure.
Old Jun 29, 2003 | 10:55 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
i already have an exhaust tip on there.So i can't mesaure from side to side. But can i mesaure around the whole thing?
I tried that it it becomes like 4 or 5 inches. is there some math formula? to use
Old Jun 30, 2003 | 09:05 AM
HeavyBreathinRS's Avatar
Car: 1990 RS
Measure around the pipe (use a piece of string, and mark the cross over point with a pen).
A steel tape will buckle trying to go around the pipe.
Then lay the string flat and measure VERY accurately.
Divide the answer by 3.142 this will give you the exact diameter (within about 10/1000 of an inch.
Old Jun 30, 2003 | 12:39 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
You don't have to measure right at the end of the pipe.
You can use a piece of cardboard.
Just cut two notches in the cardboard. One that's 2-1/4" wide, and another that's 2-1/2" wide. Whichever one fits is it.
Old Jun 30, 2003 | 08:55 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
thanks guys.
One more question....
How do i mesaure how long my tips are.
They are angle cut. Do I measure the top which is long or the bottom?
also where can i get some polished or chrome tips that are bolt on and angle cut?
Old Jun 30, 2003 | 10:10 PM
AJ_92RS's Avatar
I believe angle cut tips are measured from the longest point.
I have Magnaflow 15* angle cut, stainless steel, 3-1/2" with a rolled edge. They cost me $75 shipped from a guy on Ebay.
His user name is dirtsqurtr@aol.com
Here's one of his auctions. It's no longer active, but you'll get the idea.
I wanted the rolled edges because
1.) You can see them better when you look at the car from directly behind.
2.) I have a scar on my leg from tips that didn't have a rolled edge.
Here's a pic of mine.
BTW, you should move all your questions to the exhaust board.
toronto formula
Nov 10, 2015 06:17 AM
bamaboy0323
Sep 3, 2015 06:07 AM
transaero
Aug 31, 2015 01:14 AM
db057
Aug 22, 2015 08:17 PM
knight72
Aug 10, 2015 09:32 PM
