fuel pump problems
Old Jun 30, 2003 | 04:09 PM
IROCafros's Avatar
fuel pump problems
i have a 1986 camaro with a 89 350 tpi the fuel pump went bad the engine was originally a 305 could the pump be the wrong size? and what is the easy way to take it out and change it...I heard about cutting a hole in the trunk is this safe? or do i have to drop the axle? thanks for any replies
Old Jul 1, 2003 | 04:57 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
drop exhaust, rearend, and tank.
if the fuel pump is the org, then it most likely is bad. when i decide to change my pump out for a hi po one, once i get it out, i plan on cutting a hole in the hatch so if i ever need to change again, it will be easy.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
