HELP! TPS Sensor/Voltmeter....Quick ASAP
Old Oct 2, 2000 | 06:08 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
I set my minimum air, and now i'm on the TPS Sensor, but the article in the tech section doesn't say which wire to tap into. Plus i have no idear howto use this digital voltmeter. It has [DC] x1, x10, x100 then
[AC] x1000 then [DC mA] x1, x100 do i use AC or DC? someone please help ASAP! Need to get to school tomarrow...Just not my week to be messing with cars i guess...
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-Rebuilt 700R4 Tranny
With the goodies to go
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
Old Oct 2, 2000 | 06:14 PM
Pro Tour RS's Avatar
Got me by the short and curlies. Sorry
Old Oct 2, 2000 | 06:23 PM
Vader's Avatar
Branz,
Connect to the 'A' abd 'B' terminals on the TPS - generally the top two terminals. Adjust for 0.54VDC +/- 0.07V.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Oct 2, 2000 | 06:29 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Umm, what color are the wires supposed to be? I know one is blue and the other's are dark grey and light grey which of the grey wires do i connect to?
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
Old Oct 2, 2000 | 07:53 PM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
Transmission: 5 Speed
Black and blue wires, 20 DCV setting on your multimeter.
Old Oct 2, 2000 | 08:01 PM
Tom Keliher's Avatar
If you get 5.0 volts on your meter, remove one of the test leads and put it on another wire of the TPS. The 5.0 voltage is just a reference voltage. Other than that, you can place your test leads on either of the wires and you will be at .54 or so volt and can make an adjustment if necessary.
FORMULA 350 TK
Southern California 3rd Generation F-Body OrganizationŠ
Old Oct 2, 2000 | 10:49 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Finally got the dang thing set, thanks guys... hopefully .545 is okay?
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
Fred SS
Oct 12, 2015 11:27 AM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
92projectcamaro
Sep 24, 2015 08:09 AM
