engine + computer stuff
Old Oct 3, 2000 | 11:28 PM
FTC's Avatar
FTC
Im a fairly new owner of a 91Z. i bought the car with k+ns, a hypertech, and catback flows. its got 60,000mi. the car was neglected as far as maintenance before i changed all fluids. i am pretty clueless about computer stuff and codes. is there anything i should know about along these lines? should i have my car checked out by a mechanic as far as making sure it is running at its peak potential or is it perfectly fine the way it is. i want to make sure the engine is running as strong as it can. any input is appreciated.
new owner
Old Oct 3, 2000 | 11:48 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
You might take a look at (or have a shop look) the belts, hoses, tune up, etc.
If its a automatic, hows the trans fluid?? if its brown or burnt smelling it should be replaced.
Do a brake inspection, Basically you should check over everything that you can so you don't get stuck running metal on metal with the brakes or blowing a hose on the road.
Just a good visual inspection would really be all you need.
When buying used cars you really don't know what you are getting into.
The visual will just give you an idea of what you will be needing to do in the future, there is no way of knowing what was done in the past.
As far as the computer goes, if it runs good and the "check engine" light isn't on you should be OK.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited October 03, 2000).]
eightsixseven
Dec 16, 2024 01:50 PM
E Rod
Aug 28, 2015 05:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
