check engine...still
Old Oct 3, 2000 | 06:11 PM
84camaroz28's Avatar
I had an earlier post regarding an error
code 32 on a stock 84 305 l69 carbed camaro.
Since the first post I have put new baro
sensor,egr valve,egr solenoid,cleaned egr
port on manifold,new o2 sensor,checked and
replaced vac lines where needed.The car idles
perfectly and runs real strong.The original
problem was it failed emmisions on co being
a little high.I have not had it re-tested
because I hoped to fix the check engine first.The error comes much more frequently
in drive than when in o-drive.Also the choke light flickers abd buzzes frequently.I dont
know where to go from here,any ideas guys.
thanks
Old Oct 3, 2000 | 08:02 PM
I am thinking this problem is beyond what
I can handle.Is it time for me to take it
to a garage?Any lasts things that I can
check?
Old Oct 4, 2000 | 06:13 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
hmmm are you sure you checked all the hoses? theres a plastic one that runs inside the loom towards the fire wall into the map sensor i think, that is near the fuse box, as for the choke light, your choke could be faulty on the carb, or your alternator is going.
86 Camaro with 88 305 LB9 converted to carb, edelbrock performer manifold, S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermo, and fan switch, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
Old Oct 4, 2000 | 06:54 PM
Thanks for your response.Correct me if I am wrong,I think that sensor is also called a baro sensor?I ran a new hose to it when I
replaced the sensor.I gave up today and
brought it to a garage.I had a hard time
finding a place that is state approved to
emission test and also approved for emission
repair.This state(mass.) is unreal.I was
informed that the specs needed to pass are
intentionally designed to get the old cars
off the road and that a check engine light
was an automatic failure.Side by side comparison showed that specs for my 92 4 cyl
Toyota PU are much looser.
Old Oct 4, 2000 | 07:21 PM
ThrdGenRS's Avatar
damn government..
Old Oct 4, 2000 | 08:27 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
stupid mass, i live in CT, my car passed with no smog **** on it or cat, here's what you do, put a brand new high flow cat on that, spray a tad bit of water in the carb while it's running, and change the o2 sensor, then she should pass
Bubbajones_ya
Jul 6, 2024 08:32 PM
BumpaD82
Feb 26, 2016 02:57 PM
skeltor
Feb 2, 2016 10:37 AM
Numbah-1
Sep 12, 2015 08:57 PM
