the sound of cams?
Old Jul 3, 2003 | 12:21 PM
icebird_1981's Avatar
the sound of cams?
k well i am trying to figure out what cam i have and i was wondering if it is possible to tell by the sound of your engine. when i put my car in gear it sounds amazing (mean as hell)! just like how zepher (sp) car sounded in that video he made. any ideas?
Old Jul 3, 2003 | 02:48 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Measure it with a degree wheel and a dial indicator.
Old Jul 3, 2003 | 02:57 PM
i would but i have no clue how to do that
Old Jul 3, 2003 | 03:05 PM
Guest
Guest
Posts: n/a
step one...remove cam
step two get the dial and learn how to use it
step three put cam back in
(there is no way of telling just by the sound)
Old Jul 3, 2003 | 03:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
1. Find TDC accurately (i.e. ignore the timing mark)
2. Put degree wheel on balancer
3. Put dial indicator on push rod end of an intake rocker
4. Adjust rocker tighter until push rod stops moving (lifter bottomed)
5. Rotate crank, note degree readings for valve events - .006" & .050" opening, peak, .050" & .006" closing; note peak lobe lift
6. Put valve adjustment back where it was
7. Repeat for an exhaust valve
8. Compare to cam spec book
Alternatively you could remove the rocker entirely and put the dial indicator on the push rod end itself.
Old Jul 3, 2003 | 04:10 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
you make it sound like the task is as easy as pumping gas when its not self-serve.
haha
Old Jul 3, 2003 | 04:14 PM
i no for real everything sounded simple enough then hes like put cam back in. hu
Old Jul 3, 2003 | 05:09 PM
Guest
Guest
Posts: n/a
haha
LoL i know i just lik being a smart *** :-D the mian point to the post was that you can't tell by the sound
Old Jul 3, 2003 | 05:28 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Re: the sound of cams?
Have you tried to ask the previous owner? I assume there was a previous owner or else you would/should know what cam is in your own car...
Old Jul 3, 2003 | 05:45 PM
ok i'm no stupid lol the guy who built this car wont be back till the end of july when he gets back hes gunna give me all the paper work. its modded to the full and that all i no. but i just hate wateing. ok so u cant tell by the sound. thanks people lol
Old Jul 3, 2003 | 05:52 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
i've done many cams, motor in n motor out. Its easy but time consuming but hey, theres a smartass in all of us.
There "is" a way you can tell by the sound, its the most easiest way yet.
But your name would have to be Miss Cleo =]
Old Jul 3, 2003 | 09:49 PM
Guest
Guest
Posts: n/a
:hail: :hail: :hail: HAHHAAHAHAHA
Old Jul 3, 2003 | 10:05 PM
James Montigny's Avatar
Wanna do mine for me? LOL
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
db057
Sep 4, 2015 07:57 AM
db057
Aug 22, 2015 08:17 PM
