No RPM signal while cranking
Old Oct 3, 2000 | 11:51 AM
freeze92's Avatar
I have checked this 100 times. I still can't get a signal to my scan tool to tell me RPM's while I am trying to start my engine. '89 TPI that doesn't start well. I have an OTC Monitor 4000e. When I crank the engine, I get spark to the plugs, and the injectors are firing, according to the NOID light, but the scan tool does not show any RPM until I actually get the engine to crank. I just replaced the ECM. Anyone have any ideas?
Old Oct 4, 2000 | 08:21 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
The actual rpms while cranking are very low, maybe too low for the scan tool you are using to register.
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
Old Oct 5, 2000 | 12:38 AM
freeze92's Avatar
If I spray a little fuel into my throttle body, the car starts right up. I have 42psi at the regulator while cranking. Almost seems as though the injectors are not putting enough fuel in the engine . I don't have a cold start injector. Any more ideas?
'89 GTA, Ported Plenum, BBK throttle body, 24lb Motorsport injectors, Jet stage 2 chip, AFPR, no cats and a Flowmaster.
'95 GMC soon to be 383 daily driver w/Howell multi-point injection conversion
[This message has been edited by freeze92 (edited October 04, 2000).]
angel2794
Sep 8, 2015 06:22 PM
mddaniel
Sep 8, 2015 05:16 PM
86iroczwv
Sep 3, 2015 06:21 PM
IROCtometal
Sep 2, 2015 02:01 PM
masonta
Sep 1, 2015 06:40 PM
