Steam hole diagram for 406 heads
Old Jul 3, 2003 | 04:55 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
Anyone have a pic of the correct angle to drill steam holes in heads for a 406?
Also would there be any reason trickflow TWS G2 heads would be different then the standard angles?
Old Jul 3, 2003 | 05:24 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I just took my heads to a machine shop and they drilled the holes for 10 bucks and cleaned them up again. I thought that was well worth it.
Old Jul 3, 2003 | 08:07 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Get a 400 head gasket, and lay it on the deck as a template. Mark the holes with a center punch.
Drill the ones on the exhaust side straight in; and drill the ones on the intake side at an angle toward the exhaust.
Old Jul 3, 2003 | 08:13 PM
boogie's Avatar
That is some serious port work on that head RB
Old Jul 3, 2003 | 08:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Think they'll flow a little??
Old Jul 3, 2003 | 09:52 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Just a tad over stock flow numbers.
Nice
Old Jul 4, 2003 | 12:48 PM
Damon's Avatar
Every head is a little different. The location of the holes is always the same (use 400 gasket as a template). However, the ANGLE of the holes can vary considerably from head to head (especially aftermarket). Stock heads it's like RB said.
The main thing is that the hole has to hit the WATER JACKET on the other side. Getting the angle wrong by a few degrees won't hurt anything, but you don't want to be too far off.
355tpipickup
Aug 27, 2015 08:13 AM
trevor1010
Aug 26, 2015 02:41 PM
trevor1010
Aug 24, 2015 08:34 PM
trevor1010
Aug 24, 2015 11:29 AM
lakeffect2
Aug 23, 2015 08:44 AM
