A few fuel pump Q's
Old Jul 4, 2003 | 01:36 AM
JLP's Avatar
JLP
Car: 1983 Trans Am
Engine: 305 LG4
A few fuel pump Q's
I plan on doing an engine swap next spring and I have heard some peopl say to swap the fuel pump and hoses.
However, after talking with a friend, he says that the stock fuel pump and hoses are just fine on a carberated engine. My engine will be about 400-450 horses, is he right on this? Im inclined to beleive him, just want to make sure.
Second question, on a 305 engine, the fuel pump is mounted on the engine by two bolts, or is it mounted in the gas tank???
Lastly, bigger hoses = better?
Old Jul 4, 2003 | 07:28 AM
ede's Avatar
ede
look at your engine and you'll know if the FP is mounted there or not. stock may be just fine for you if you had botherd to say what stock was. larger lines= more volumn which isn't bad but it may be unneeded depending on your application.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
