Can I use the Camaro TPI air induction on a Camaro with a Firebird L98?
Old Oct 6, 2000 | 03:52 PM
CamaroX84's Avatar
I have an 84 Camaro with a 305 TPI motor that I put in. I just found an 89 Firebird with the 350 TPI motor. Will the air induction on the Camaro motor work with the Firebird motor? From what I've heard the air induction is different on the Firebirds. Thanks.
Old Oct 6, 2000 | 04:18 PM
Ed Z28 350's Avatar
Quote:I have an 84 Camaro with a 305 TPI motor that I put in. I just found an 89 Firebird with the 350 TPI motor. Will the air induction on the Camaro motor work with the Firebird motor? From what I've heard the air induction is different on the Firebirds. Thanks.
Assuming the 305 TPI is from 85 - 86, do this:
Use the TPI manifold base, knock sensor and injectors from the 89 engine. Use the runners, plenum, MAF and other sensors from the 85 engine. Either use headers or the 89 exhaust manifolds because the 85 exhaust manifolds will not clear the centerbolt valve covers. The different air induction refers to the air filter housing and ducting. Retain the 85 TPI stuff. As far as a chip is concerned, I will defer that recommendation to someone who actually knows which chip to use
Edwin
1986 IROC, 1992 Body Kit, 1989 5.7 IROC Engine, Crane Cam, 3" CVX Exhaust, ADS Superchip, 24# FoMoCo Injectors, Gutted Cat, AFPR (45 psi), Airfoil, 3.42 Gears, MAF Screens removed, Gutted Airbox, K&N Filters
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
matthew911
Aug 12, 2015 09:38 AM
