How much $ to go 383 or 388??
Old Oct 5, 2000 | 11:01 PM
Brandog87GTA's Avatar
While I am rebuilding my engine from nos mishap, I am wondering how much it would cost me to just go stoker. I will be using camel hump heads, vic jr intake, and a cam to match.Which is better 383 or 388?
Bright red 87 GTA with 350 tuneport. Basic mods such as K&N filter, Flowmasters, Wells MAF, TPIS air foil, Accel 8.8mm plug wires with , Accel distributor cap and rotary buttons.Gutted cat. B&M Shift kit, 100HP shot Nitrous, soon to change over to carburator.
Old Oct 6, 2000 | 09:02 AM
Polecat's Avatar
Let's see, a 383 or 388. Basically the same, just differnt bore over. You can get a great stroker kit from www.speedomotive.com but on the heads, they are great for torque. On the old days, they were great. Compared to now day technology, get a set of Sportsman II's or Dart Iron Eagles. Something in the 200cc runner area and 64cc combustion chambers.
The intake would be a bad idea in my opinion. Why? You build a 383 for low end torque, but will hurt it by putting an intake that is the RPM range from 3500-8000.
Get an RPM intake, it will give you the best throttle response and will pull to 6500, which is plenty for a 383, trust me. I had #186 doublehump heads, so been there done that.
Good luck!
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,Hypereutectic pistons,9.8:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, K-Motion springs, Comp Cam 1.6 roller rockers, Lunati adv.292/230@.050 with .512 lift,Crane pushrods,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
[This message has been edited by Polecat (edited October 06, 2000).]
Old Oct 6, 2000 | 02:32 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Unless you have already reconditioned those camelback heads, I would suggest selling them to someone looking for "vintage" pieces for their classic car and buying a set of aftermarkets like the World Products heads, or some Dart Iron Eagle castings. They flow better than the camelbacks, and wouldn't require the extra work of reconditioning. When it is all said and done, your camelbacks will probably cost you $300 to $400 to get rebuilt, whereas a new casting that offers superior flow, will cost $650. Subtract $100 for the money you get by selling the camelbacks, and you are within $100.
All IMHO, of course. I've been there with a set of 305 castings: I have $460 tied up into them!
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines,
5-point racing harness, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Speed-sensitive steering conversion, underdrive pulleys, Crane Hi-6 & more. 1.05g skidpad verified.
New best E/T! 14.400 at 98.6 MPH in 88 degree air at Stanton, Michigan.
Old Oct 6, 2000 | 04:52 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
If you go 388 have the block sonic tested.
-Auggie-
Old Oct 6, 2000 | 05:51 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
I can't stress this enough. Only overbore as much as is needed to clean up the cylinder walls, overboring is not for getting you HP, just wasting money if not needed!
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
