considering a 350 swap
Old Oct 5, 2000 | 08:03 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
well...i WANT to swap in a 350 and give it 450 hp. with new heads cam rockers lifters intake headers catback etc...but the question is....i have a 305 tbi in my 90rs. when i buy the stock replacement 350 from SDPC2000 ($1300)...will i have to transfer over my TBI unit making it a 350 TBI or would i go to the junkyard and get TPI parts. which would be more beneficial/helpful to my 450hp goal. thanks a lot guys.
also i need a new chip right, and fuel pump, and injectors???
Old Oct 6, 2000 | 12:17 AM
IrocManiac's Avatar
The TPI would be more effecient but if you want to make 450 horsepower this will be harder with the stock runners and baseplate.
I would buy the top manifold the wiring harness from the salvage yard or used from a place that will check it out for you. There are probably some places in your area. There are four here in OKC. Get 24lb injectors when you by injectors. Get SLP headers if you can afford it I hear they are the best but not for sure. Ask around about the Cam and Headers. Also get a custom burned chip.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
Old Oct 6, 2000 | 06:34 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
a carburator would be most beneficial for your project. Making 450 fuel infected HP with a stock like design on the TPI will cost you a lot of money that you could use to attiain your 450HP goal.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
Old Oct 6, 2000 | 07:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You're going to have to go computer controlled carb if you want any prayer for pass emissions testing. If your car was built after they stopped making carbs, even prayer won't help.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 open. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, ported heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
[This message has been edited by five7kid (edited October 06, 2000).]
xkingcodex
Feb 12, 2020 07:43 PM
bellez77
Sep 5, 2015 08:39 PM
theshackle
Aug 22, 2015 06:52 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
