Fuel Filter Replacement
Old Jul 6, 2003 | 05:27 PM
gcore45's Avatar
Car: '91 RS
Engine: 5.7 tbi
I've just replaced the fuel filter on my Camaro and developed a leak from the fuel fitting screw where it meets the pipe. This is on both sides of the filter. There was no rubber gasket in the packaging for the filter. Should there be a gasket/o-ring?
Old Jul 6, 2003 | 08:34 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
http://www.dougrippie.com/images/Fl6.jpg
That is a flare type fitting, there should be no gasket or O-Ring. Be sure you go in straight and tighten it good, it is a metal to metal seal.
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
92camaroJoe
Aug 13, 2015 06:07 AM
