Need to hook up adjustable map sensor-what can I use as a 12 volt power supply?
Old Oct 7, 2000 | 05:50 AM
BK's Avatar
BK
I'm ordering the adjustable map sensor from turbo city on Monday and I need to hook it up to a 12 volt power supply. Should I hook it up to the battery or is there some other place to wire it?
Old Oct 7, 2000 | 09:42 AM
Josh91Bird's Avatar
Car: 1991 Firebird
Engine: 412ci/sb
Transmission: Built 700R4
I have the same MAP. I found a wire with a multimeter that was hot when the key was on and spliced it on to that wire with a connector. Just search around with the multimeter and you will find a hot wire. I could tell a small difference with thier MAP but not enough to justify $80...let me know how yours goes and reacts to the new sensor.
91 Firebird 305/TBI - cam:.420/.442 204/214 - Hooker 1 5/8" headers - TFX PaceSetter Cat-Back - 3.42's Auburn Pro Posi - ASCD Ram-Air hood - Polished Formula Wheels w/Futura's - Open element - .5" Corian TB spacer - Lakewood LCA's - Hotchkis Lowering Springs - KYB Struts/Shocks - 14.78 @ 97.5 mph(G-Tech) - MacEwen MotorSports Whiteface Overlays - 412ci sb waiting to go in this spring.
My Homepage
92camaroJoe
Jul 29, 2023 07:57 PM
L98GTA87
Aug 25, 2015 02:23 PM
Accerrito22
Aug 23, 2015 07:22 PM
92camaroJoe
Aug 13, 2015 06:07 AM
