tach drive dist
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
tach drive dist
hello- i fpound a mallory unilite with the tach drive for a corvette. could this be used as a regular dist?
Car: 86 camaro
the situation is i have a mallory comp 9000 dist that the cap is too big for a intake carb i want to try. this dist has the smaller cap but has the mechanical tach hookup. the guy who has it thought it was only for late sixties corvettes . its got the same plug as the one i have now.
Car: 4
Engine: 6
Transmission: 5
It should work then, there's no requirement that the cable drive be hooked to anything. I was more referring to things like computers, it wouldn't interface readily to FI for example.
