Fuel injector question
Old Oct 7, 2000 | 08:08 PM
Iroc_Z28's Avatar
ok heres the problem i have a ticking noise coming from the engine when accelerating once you get up to what ever speed you are going to you cant hear it anymore but if you give it the gas it to make it go harder i can hear something ticking ....i know it isnt the valves or the rods or the rocker arms....any help is appericated
Old Oct 7, 2000 | 08:12 PM
BIGJsTA's Avatar
does the ticking get faster or louder at faster speeds? or faster or louder at higher RPM's? or does it stay constant? Have any battery charging problems? Does it do it at idle, if so, try pinpointing the sound to 1 area. Really dont have too many idea's from what you said sorry, alot of stuff can click, try driving it a bit and making it click and see if you cant pinpoint it a bit more or get more info i'd say. Unless someone else can help
Old Oct 7, 2000 | 09:31 PM
Iroc_Z28's Avatar
the noise does get louder with increased speeds but once you get to a steady speed it doesnt do it...i have replaced the alt..and the belt....it is on a 87 iroc and it sounds like it is coming from the drivers side
Old Oct 7, 2000 | 09:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Could be an exhaust leak from a single cylinder. Do you have headers? Could also be a cracked or loose manifold.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 open. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, ported heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Oct 7, 2000 | 09:49 PM
BIGJsTA's Avatar
Exaust leak makes sense, but wouldnt that cause the clicking to get faster? Anyway i just remembered, my compressor used to do that. Made me really worried, till my grandfather (mechanic) heard it and checked my AC, since i have a leak and no freon left, the compressor clicks in and out kinda fast, but that was mostly at startup, it would get louder when i went faster, but usually once i got moving it went away.
Old Oct 7, 2000 | 09:52 PM
FastBroker's Avatar
I think it's exhaust, too. Yeah, ticking will get faster but it's rather hard to discern. Just look for a leak or for header/manifold cracks.
MustangBeater20
Oct 29, 2022 09:20 PM
bryan623
Mar 22, 2021 06:43 PM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
