GM 383 crate engine??
Old Oct 8, 2000 | 01:58 PM
87GTA350's Avatar
has any one heard of buying the 383 crate engine in short block for as a starting point for building a good stroker engine?
Old Oct 8, 2000 | 02:44 PM
Blade's Avatar
What's to hear about it ? There's absolutely nothing wrong with doing that.
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Old Oct 8, 2000 | 03:57 PM
87GTA350's Avatar
let me rephrase the qestion... is this a good block to start with giving the fact that i want to SC the engine with about 8-12 psi after build is done..or is it better to start from scratch and order specific parts
Old Oct 8, 2000 | 07:04 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
If you are looking into using a shortblock from a particular company I would call them up and explain to them that you are planning on running a blower. Find out what type of abuse the parts they are using will cost and find out if adding a super charger will void any warranty that the shortblock may have.
theshackle
Mar 5, 2017 06:37 PM
masonta
Aug 31, 2015 10:14 PM
ezobens
Aug 19, 2015 10:29 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
