TPS adjustment
Old Jul 9, 2003 | 12:47 AM
Vicious 88 GTA's Avatar
TPS adjustment
How can I check the voltage on my TPS...I usually adust it manually til I feel it is alright...it has worked so far... and what should I set my base timing at, also the distributor timing...I am planning to do a complete tune up on it again after I get the cat cut off and install a Hooker Aerochamber exhaust on it. also what should I gap the plugs to....and is there any suggestions that I should do? I have heard about this MAF burn off, what should I do to check if it is ok? I am also considering taking off the A.I.R. system, will it affect anything and how hard will it be? - AARON
Old Jul 9, 2003 | 12:16 PM
Vader's Avatar
Vicious,
And for a little background data:
  1. Are you getting DTCs? (Error Codes?);
  2. Is the A.I.R. system causing problems? Normally, they don't;
  3. Is the cat causing a problem? (See above);
  4. Do you really expect to gain anything from their removal?
  5. If you're not getting error codes, is there some other reason you're concerned about the MAF?
Performing a complete tune up may solve a lot of the issues you may be having, although you really haven't listed any.
A complete tune up on your engine includes:
  • Cooling system inspection;
  • Clean or replace spark plugs;
  • Ignition wire testing;
  • Distributor cap/rotor (if you don't have the OptiSpark);
  • PCV valve cleaning or replacement;
  • Vacuum hose inspection;
  • Air filter;
  • Cleaning the throttle body and IAC;
  • Adjusting mixture control and choke/pulloff/idle (carbed engines);
  • Checking/setting TPS voltage;
  • Check/adjust minimum air rate;
  • Check/adjust timing;
  • Code scan.
Once you get that taken care of, you may not want to sell the car, and may discover that the cat and air injection aren't a problem.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Reid Fleming
Oct 10, 2015 09:56 PM
meeklay812
Oct 1, 2015 03:46 PM
FormulaEngland
Sep 30, 2015 01:50 PM
