adjusted valves now gas milage SUCKS!
Old Jul 10, 2003 | 02:19 PM
bad_ta_05's Avatar
Car: 85 trans am
Engine: 79 4 bolt 350
i have an 85 trans am with a 79 truck 350 in it, i adjusted the valves by setting them at 0 lash while its running, then shut it off and turn them 1/2 a turn to set them. now it runs great, starts much better, no hesitation or anything but my gas milage is HORRIBLE! should it have affected it that badly?i also have an edelbrock 600 cfm carb. should i re adjust the carb or should i start looking for a fuel leak? if you think its a fuel leak where should i look at? thanks alot
Old Jul 10, 2003 | 02:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I doubt the valve adjustment had anything to do with gas mileage. I'd be more inclined to suspect something else got bumped or altered during the process, or failed or changed at about the same time.
Check to make sure the timing isn't grossly retarded, and the vacuum advance is hooked up and working.
Old Jul 10, 2003 | 02:33 PM
bad_ta_05's Avatar
Car: 85 trans am
what could i have bumped or altered? i didnt touch any fuel lines and they are still hooked up and in good shape. timing shouldnt have jumped from just pulling off the valve covers. i just had the carb set and the timing set by a gm mechanic i know so the vaccume advance and timing should still be right on the money. i have no idea what could have happend to make it soo bad. and i have no idea how i can fix it
Old Jul 11, 2003 | 02:37 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Half a turn is kind of a lot after zero lash isnt it? I always do mine 1/4 turn after zero lash while the engine is running. Much better that way.
Old Jul 11, 2003 | 02:48 PM
bad_ta_05's Avatar
Car: 85 trans am
the 1st time i did it, i did 1/4 turn at zero lash, but it didnt do anything but make my gas milage worse, still had a hesitation and stuff so then i did 1/2 turn, didnt really hurt the milage but it took out the hesitation and fixed all the performance problems i had with it. it runs awsome but now my milage sucks. 1/4 turn wouldnt affect it that much would it?
Old Jul 11, 2003 | 02:59 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The factory says one full turn; so no, ½ turn is not alot, that's about what I use for a street-driven motor.
My opinion hasn't changed; the valve adjustment is not the problem. Something else was disturbed, or broke at about the same time. Forget the valve adjustment if you did it right which it sounds like you did. Look at your carb, vacuum lines, fuel lines, gas tank, timing, wiring, etc.
customblackbird
Aug 15, 2021 10:16 PM
86White_T/A305
Aug 17, 2015 12:16 AM
BurlyChev
Aug 16, 2015 09:08 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
