What egr vavle do I have is it a p or a n, 86 lg4.
Old Sep 20, 2000 | 09:37 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Well IHave a 86 lg4 car and was wondering what egr vavle I have, I would like to get a new one. Thanks, oh the car is carbed.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Moroso Blue max wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Sep 20, 2000 | 09:40 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Look at the part number on the valve.
Should be a "P" or an "N" at the end of the number.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am, flowmaster,FRA,Pro Kit,BMR STB, polished calipers.
1986 Chevy 3/4 ton pick up,flowmasters,4.10s,
1981 corvette FOR SALE
1995 ZX6R,Yosh,D207s
GO #3
Old Sep 21, 2000 | 06:40 AM
BLACK Z's Avatar
Car: 86 Z28
I can't read the number, If it was replaced Could they put the wrong one on? or do They each hook up diffrent?
Old Sep 21, 2000 | 08:07 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
My experience is that you don't NEED the number (they can go by application) but to make sure it is the right orofice size you should get the number.
Can you wire wheel the valve to beter see the number??
Your GM dealer should be able to match it up pretty good, the number just makes you sure that its the right one.
GO #3
Old Sep 21, 2000 | 02:30 PM
Highwind's Avatar
Car: 1988 Firebird
Engine: 305 TBI
Just take it off and take it to auto store to match it up, but take it off carefully so that you can put it back on if needed (Just make sure to vaccum all that carbon out of the port before you put it back on). When I got mine for my 88 Firebird the gave me one that didnt fit. Then they looked up the part # on my original one and they couldnt locate it. Finally we matched one up which was from an 87 Firebird (I dont remember the engine type). So their computer kept giving wrong part #'s. My new EGR valve cost me about $46. The quote I got from GM was for about $60.
Shouldn't bother putting this but hey what the heck:
1988 Maui Blue Firebird 305 TBI stock
Old Sep 24, 2000 | 10:27 AM
BLACK Z's Avatar
Car: 86 Z28
do the n and the p's look alike will they interchange, I don't mean will either work I mean will they both bolt up?
Old Sep 24, 2000 | 10:41 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
I belive, in certain applications, they will bolt up.
Don't know for sure...never tried to switch em.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited September 24, 2000).]
Old Sep 25, 2000 | 06:44 AM
BLACK Z's Avatar
Car: 86 Z28
sorry man for all the ? but do they hook up the same mine has to vac lines one run's from the thermo stat housing to the egr and the other to the exaust somewhere I think.
Old Sep 25, 2000 | 06:46 AM
BLACK Z's Avatar
Car: 86 Z28
I also have a solnoid if that helps.
Old Sep 29, 2000 | 06:40 AM
BLACK Z's Avatar
Car: 86 Z28
CAn anyone tell me for sure?
Old Sep 29, 2000 | 08:03 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Yes they hook up the same.
You need to get a vac. diagram if you have any questions about the way it hooks up.
Look at the underhood label or maybe Vader has a diagram for you. (that guy has all the cool pictures )
I don't have one here in front of me.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited September 29, 2000).]
Old Sep 29, 2000 | 08:33 PM
BLACK Z's Avatar
Car: 86 Z28
The underhood label is gone?
Old Oct 4, 2000 | 06:48 AM
BLACK Z's Avatar
Car: 86 Z28
IS there any other way to tell?
Old Oct 4, 2000 | 08:20 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
I have one diagram that shows constant vac. to the solenoid on one side, (this could also split to other sensors that need constant vac.),and the vac. line goes to the EGR on the other. The ECM signals when to command the EGR on and the solenoid opens allowing vac. to the valve.
If you need a new valve and the number is gone/missing I would take it to the dealer and match it up.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited October 04, 2000).]
Old Oct 5, 2000 | 06:44 AM
BLACK Z's Avatar
Car: 86 Z28
What happens is I got a new vavle a few years ago, I still get the code 32 even though I put a new vavle in, I never botherd to check the old vavle so I don't really know what it was the new vavle has a n on it, It has a line that goes to the thermostat houseing and another that goes maybe to the exaust?
Old Oct 5, 2000 | 08:46 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
We REALLY need to find you a vac. diagram.......anybody???
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
Old Oct 6, 2000 | 06:46 AM
BLACK Z's Avatar
Car: 86 Z28
That would be cool.
Old Oct 6, 2000 | 08:45 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
I'll check at work....see what I can find.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited October 06, 2000).]
Old Oct 9, 2000 | 09:29 PM
BLACK Z's Avatar
Car: 86 Z28
Did you find anything?
Old Oct 10, 2000 | 12:07 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
I think the manual I need is at the shop next door. I'll go get it tomorrow.
I forgot the other day and remembered today (OOPs, sorry)
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
Old Oct 10, 2000 | 07:48 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
This is what I have for a 86 305.
Vac. comes from port "J" which is the front pass. side vac. port at the base of the carb.This is the port that kinda sticks out at about a 7 o'clock position in the carb base.
Looking at the carb from the front of the car there should be 5 places for vac. hoses , from left to right..
"J" To EGR solenoid
"B" To air cleaner base
"L" To PCV valve/air management valve/EFE TVS
"T" Canister control valve
"M" Canister control valve
From the EGR solenoid it goes to the EGR valve.
Thats all I show. Hope this helps.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited October 10, 2000).]
Old Oct 10, 2000 | 09:27 PM
BLACK Z's Avatar
Car: 86 Z28
Are they labeled on my carb J B and so on? if not how would I know which is which I would really like to make sure everything is hooked up right, And where should my map sensor go? Thanks a million joe.
Old Oct 10, 2000 | 10:51 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
"Joe"???
The EGR one should be the port on the base plate of the carb that is under the choke pull off. The post sticks out at about a 7 o'clock position looking at the carb from the front.
the map should go to the rear of the carb "N", this should be the only small port back there.
This diagram is actually a 85 diagram, according to this book they are the same.
Hope this helps......Bill
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
Old Oct 10, 2000 | 11:07 PM
matthew's Avatar
I think I can help. I asked vader a question about vaccum lines a while back and he posted a diagram. I'll see if I can find it.
Hope this helps
Old Oct 10, 2000 | 11:19 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Thats the diagram I have, just didn't have a way to post it.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
