hesitation...stumbling
Old Jul 12, 2003 | 11:46 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
I've got an '89 IROC 5.7L. The voltmeter was dropping down to around 9 or 10 volts after I put in my SPAL electric fans. I figured that was it and installed a Powermaster 140 Amp alternator. Now the same thing is happening and it's causing hesitation at times. What else could be causing this? Bad battery???
Old Jul 13, 2003 | 12:02 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Make sure that all connection bolts (ie. ground) are all metal-metal. Sand off any paint ot rust under them. That may help.
