Sportsman II heads rocker arm question
Old Jul 15, 2003 | 08:18 AM
nes_t_383's Avatar
Hi, I just had a quick question on what type of rocker arms are used on the Sportsman II cast iron cylinder heads. This is exactly what it says on the spec sheet for these heads : "Sportsman II heads utilize a standard offset rocker designed for the Small Block Chevy". So, my question is can I use regular smallblock chevy rocker arms or do I have to get a special set of offset rockers? Also, anyone who has these set of heads, please let me know what you are using. Thanx.
Old Jul 15, 2003 | 08:28 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
standard offset
That means no offset at all.
Just FYI.... what they're talking about, is on serious-effort heads, the push rods are extremely in the way of growing the intake ports, and one way to gain clearance there is to use offset lifters (real rollers of course, not the stupid factory rollers, remember we're talking about serious effort here) and rockers with the push rod end moved outward, to allow a wider intake port. The same sort of thing happens at the other end of the rocker; in order to put larger valves than 2.02"/1.6" in a set of heads, the guides have to be moved apart in the casting to a greater spacing than stock, which then offsets the valve end of the rocker outward too. Of course, most people who would be building motors of this sort, are using shaft-mount rockers such as Jesel; not stock-style stud-mount ones ones. The S2 heads aren't near big enough to need any of those adaptations.
So this would fortunately fall into the class of things of "if you have to ask, you probably don't have to worry about it".
I'd suggest the cast steel-bodied roller rockers from Comp, either the 1300 series, or if you feel like really biting off, the 1100 series. If you're going to run these on the street, avoid aluminum; and of course, no matter what, avoid any kind of cheap stamped sheet-metal ones.
Old Jul 15, 2003 | 10:34 AM
nes_t_383's Avatar
Thanks alot for the information.
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
Cameeeero
Aug 20, 2015 03:06 AM
redmaroz
Aug 16, 2015 11:40 PM
