fuel pump relay
Old Jul 15, 2003 | 03:01 PM
85Rock's Avatar
Car: 1985 IROC
fuel pump relay
On an 85 iroc 305 tpi. Should the fuel pump always start when the key is turned to the accesory setting. Or does the system hold pressure for a short time. My car does not always want to start right up. I thought that it may have been the relay. because the fuel pump does not start every time the switch is turn on. Any suggestions would be helpful. I did change the relay just to see if that fixed it and it seems to do the same thing? Bad relay? thank you Kris
Old Jul 15, 2003 | 03:09 PM
Vader's Avatar
85Rock,
Welcome Aboard!
The fuel pump relay should not run with the key in the ACC position. It should operate for about two seconds when the ignition is turned to RUN. It will also operate as soon as the ECM receives reference pulses from the distributor (engine moving).
Also, the pump relay will not operate on successive ignition power-ups unless the ignition power has been off for at least 20 seconds.
Verify the fuel pump relay operation. If the relay is operating correctly (on power-up) you need to monitor the fuel pressure. Your stock injectors require at least 33 PSIG to operate satisfactorily, and should normally have 38 PSIG (+/- 3 PSIG) with the engine running.
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
