engine rapping
Old Jul 15, 2003 | 11:14 PM
USMC RCT's Avatar
Car: Trans Am
engine rapping
hey all
not to sure whats wrong with my engine. its makein a sort of rap/nock when i rev it up past 2000 or when its gotta work goin up the big hills i got here in nh. is my engine shot or what? its not real loud but like i said when i make it work or jump on it it makes that noise, thanks in advance for your help you guys are great, oh yeah its a 86 trans am with a carbed 305
Old Jul 16, 2003 | 12:13 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Could be an exhaust leak.
Old Jul 16, 2003 | 09:44 AM
Vader's Avatar
I wanna tell you ‘bout some noise that my engine makes,
It be a knockin' and a rappin' and sometimes it shakes...
Boof - Bump - Boof - Bump
It does a knock and a thump and a little clang.
I don't wanna get beat by no chump Mustangs..
When I'm slidin' up the hills it does it even mo'
It ain't cool makin' noise when I'm crusin' for hos...
I bust out from my homies ridin' their Accords
I don't need my ride soundin' like no Fords...
Obviously, 40-something white guys shouldn't be allowed to write rap lyrics.
Do you notice any cold start noise? Is the noise more RPM-dependent or load -dependent? Oil pressure normal?
Old Jul 16, 2003 | 11:22 AM
USMC RCT's Avatar
Car: Trans Am
exhaust leak will sound like a nock? what would be leaking? oil pressure is fine (i think, it always stays right around 30). the noise is more rpm dependent and no wierd noises when i start it just a puff of smoke. by the way that rap was prolly the funniest thing ive even seen :sillylol::hail:
Old Jul 16, 2003 | 03:53 PM
Air_Adam's Avatar
It (exhaust leak) will sound more like a metal-on-metal tapping sound, as if a rocker arm came loose.
It just leaks exhaust gases.
And well done Vader!!!
Old Jul 16, 2003 | 06:02 PM
USMC RCT's Avatar
Car: Trans Am
but what would make a exhaust leak sound like that? could someone clarify this for me? thanks
Old Jul 16, 2003 | 09:52 PM
Vader's Avatar
If it's only occurring under heavier loads, it could be detonation/preignition (spark knock).
Are you using lower octane fuel with higher compression and advanced timing? Hot engine/heads? Lean mixture? They can all contribute to detonation.
Old Jul 16, 2003 | 10:41 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
does it only do it underload or does it do it just sittin there when you rev it? can you narrow down where the sound is coming from? grab a piece of hose or a prybar or something and put one end to your ear and one to various parts of the engine (heads/valve cover area, manifolds/headers, and go over the lower portion of the block) the way you describe it, it sounds like its preignition or possibly a rod knock.. kinda vauge discription.. if it only does it under load i think vaders got ya covered with preignition.. another possible cause for preignition could be excessive carbon deposits..
Old Jul 17, 2003 | 07:35 PM
USMC RCT's Avatar
Car: Trans Am
ok thanks guys ill check it out tomm when i can see what im doin
Old Jul 19, 2003 | 07:16 PM
USMC RCT's Avatar
Car: Trans Am
ok it def olny makes the noise when its in gear, when i rev it in neutral its sounds perfect, i havnt mess with anything with the car exept puttin a k&n filter in
Old Jul 20, 2003 | 02:30 PM
USMC RCT's Avatar
Car: Trans Am
and i use the cheapest gas at the pump
Old Jul 20, 2003 | 03:06 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
check your timing.. it may have slipped.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
