balancing weight on flex plate
Old Jul 16, 2003 | 01:29 PM
jimmy_mac's Avatar
On a 1 piece rear main seal crank on the late model 305s. Which side does the weight on the flex plate sit on when it's installed. Is it on the engine side or the towards the rear of the car?
I know the flex plate says which way to go, but it's already installed and the motor is in. and the weight is the only thing I can see without unbolting it and pulling the trans back.
Old Jul 16, 2003 | 02:26 PM
ede's Avatar
ede
out or to the rear, but it's been a while since i saw one.
Old Jul 16, 2003 | 08:07 PM
Damon's Avatar
As long as the little "pads" on the flexplate that the torque converter bolts onto are bubbled out TOWARDS the torque converter it's installed the right way around.
Old Jul 17, 2003 | 08:55 AM
jimmy_mac's Avatar
Thanks guys, and Damon thanks for pointing that out. Now that you mentioned the "pads" it seems a little obvious
Old Jul 17, 2003 | 09:11 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I thought the holes were asymmetric, so the weight would be in the right place relative to the crank (and therefore it couldn't go on backwards, anyway).
Old Jul 17, 2003 | 09:25 AM
jimmy_mac's Avatar
I don't know, I'm at work so obviously I'm not able to look at it right now. That would make sense but then why would they stamp that sentence on their "this side faces motor". Hmm.
Whole reason I was checking is the new starter seems to be chewing up the flywheel. And the motor is newly installed. I know it's offset from the mating surface so if it was on backwards the gear would probably not be fully engaging.
loud91rs
Oct 5, 2015 10:05 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
Damon
Sep 26, 2015 04:29 PM
