Trouble code 34 on 88GTA 5.0TPI
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
I keep getting this trouble code even after changing the MAF sensor. All connections seem OK and the SES light will come on at times. I also have adjusted the minimum idle screw and the TPS according to the book.
I read on an article that this might be a faulty code. Any sugestions on this.
Car: 1984 Z28
Engine: 305 LG4
I had the same problem on my 88GTA w/305. I replaced both the Burn Off and Power relay for the MAF sensor, reset the computer by disconnecting the battery for 1 minute. Never had the problem again. I picked up the relays for about $12 a piece I think. They're located on the firewall next to the master cylinder. There's actually 3 relays I believe, one of them is for the fuel pump.
Good Luck !
Tony
88GTA 5.7 (was 5.0)
Ported plenum, MAF Screens removed
AFPR, K&N Airfilter, Airfoil
TB bypass
Free-flowing CAT,
Mufflex 3" Cat-back w/SLP muffler
Good Luck !
Tony
88GTA 5.7 (was 5.0)
TB bypass
Free-flowing CAT,
Engine: 5.0 TPI
Thanks for the tip. Think I'll try that. I had just read something on the relays and wanted a second opinion.
Thanks again.
Thanks again.
