Question about the L98
Old Jul 17, 2003 | 03:39 PM
dragonfyre88's Avatar
I have a question about the l98 engine:
Will the T5 5 speed transmission bolt right up to the engine like it would to any of the engines.... The reason i ask is because the tech data on thirdgen.org doesn't have a listing for the manual 350.. thanks
Old Jul 17, 2003 | 04:02 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
yes it will bolt up.
Old Jul 17, 2003 | 04:22 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
The reason it's not listed is because the T5/L98 combo was never mass produced. Evidently the T5 isn't strong enough to handle the torque.
WOM has it that GM did produce a few that way, but I've never seen one documented.
If you're going to do it, go to the transmission board and do a few searches. It's not much harder to install a T56 instead, and they're MUCH stronger.
Old Jul 17, 2003 | 05:00 PM
Car: 1988 IROC-Z
and it's a 6 speed.
in case you don't know what a t-56 is.
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 19, 2015 10:07 PM
redmaroz
Aug 16, 2015 11:40 PM
matthew911
Aug 12, 2015 09:38 AM
