CLUNKING IN REAR END!
Old Oct 13, 2000 | 05:44 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Hey guys, I just had a carrier 3 posi unit and carrier 3 GM Motive 3:42 Gears installed with my rear end. Well I get the car back and now my rear end is clunking big time! I bought the posi additive and they put that in my posi so I don't know what it could be! It happens in reverse, when I turn, come to a complete stop and when I am sometimes going off the line. I am in the process of breaking in my gears as we speak. Have about 20-30 miles left. I called the rear end shop (which is well known where I live) and he told me that the posi additive just has to work its way into the posi unit. He told me to do a bunch of 360 circles slowly in one direction and then in the other direction. I have been doing that today and so far no difference. What happened and what should i do?
Eric Natzke
91 Firebird 305 TBI (ZZ4 summer of "01")
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-Accel Cap & Rotor
-Rapidfire Plugs-Pablo's Free Mods-265/50/R15 Tires-Emmison's all Gone
http://hometown.aol.com/J007Golden/index2.html
Old Oct 13, 2000 | 05:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Try doing about 10 figure 8's in an empty parking lot. If it still does it after that, either change the lube (try synthetic this time - guess my favorite), or take it back to the shop to have them check it out. Others have said an extra treatment of friction modifier did the trick.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 open. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Oct 13, 2000 | 07:29 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
Hey they got a warranty, you called 'em let 'em know what was going on. If you blow the gears and/or the posi system they have to pay so knock yourself out! (just don't pop the clutch or something that will obviously blow the gears). Worst case you get stuck and they eat the towing. Just call them again and make sure that they don't want to take a quick look.
Corry
Old Oct 13, 2000 | 07:50 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Thanks but I already paid for the gears and posi (used) so no warrenty. I they might be right but it should have been broken in by now. I will try doing the figure 8 thing and 360 thing again tommorow. They said if it still does it then to bring it in Monday. U think that this is it? That the additive just hasn't gotten into the posi unit?
Eric Natzke
Old Oct 13, 2000 | 11:05 PM
Corry's Avatar
Car: 1987 Trans Am
I personally don't have the seires 3 carrier, but I had t odo my gears 2x. (Long story) They didn't clunk until they were dead. The second time they went, somehow the rinb bolts loosened up (although locktite, was used, and the bolts partially mushroomed, and were torqued properly......) and the pinion gear came loose, moved probably 300 thousanths out of tolerance. Ripped the top half of the gear right off (and these were richmonds) That thing when it went sounded like a point blank gunshot, followed by loud clunking w/ every turn of the driveshaft. The time before it didn't make quite as much nosie when they went. Either way though, on a series 2 carrier, I have never heard of posi fluid not makinng its way in. I don't know about the series 3 though. Sucks about having no warranty...I know how expensive the gears and carrier are.
Good luck
Corry
Old Oct 14, 2000 | 07:41 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Hey thanks Corey. I was wondering, I never heard of a carrier 2 posi unit?
Eric Natzke
-Rapidfire Plugs
Old Oct 14, 2000 | 01:56 PM
Corry's Avatar
Car: 1987 Trans Am
Mines a series 2 carrier. Has Posi. I checked, it's a GM series 2 carrier. It's not the auburn rear. 7.625/7.5" ring gear. 35 ft/lbs of torque is required to spin one tire, and not the other.
Let me know how it works out. Just because I haven't hear of having to work in the posi lube.
Corry
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
