Gasoline smell, need help ?
Old Oct 14, 2000 | 12:02 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
I have a strong gasoline smell by the drivers side rear of the car, what could be the possible causes, here's what ive done.....
New Carbon canister
New plugs and wires,
New Cats,
New throttle control sensor,
New Gas Cap,
What could be some other causes ?
Old Oct 14, 2000 | 12:18 PM
Blade's Avatar
Did you check on the recall they have on 91-92 Camaros for this ? The weld that holds the neck of the tank to the tank might crack and cause gas vappors and/or gas to escape trough it. Call in the VIN to a dealer or let them inspect it. If that's the case it will get fixed for free.
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Old Oct 14, 2000 | 01:19 PM
ede's Avatar
ede
there's also a vent from the tank in that area.
-=ICON MOTORSPORTS=-
Old Oct 14, 2000 | 02:29 PM
91Z28's Avatar
Car: 91' Z28
It seems as if the smell is comming from the little plastic vent, which is connected to the chassis, it has a black hose connected to it
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
Dwayne614
Sep 29, 2015 11:05 PM
Racerx974
Sep 19, 2015 10:16 AM
Glowsock
Sep 11, 2015 11:09 PM
