Question about TPIS ZZX cam lobe.
Old Jul 18, 2003 | 10:04 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I was degreeing in my cam today and noticed that there is only .358 lift on the lobe. According to the cam card it's .372. Am I measuring wrong? I have the lifter in the bore and the dial indicator with a magnetic base sitting on the deck surface. The indicators plunger is on the lifter as it's supposed to be. The plunger is also at the right angle just as it was a pushrod. The valve lift should be .558 and it will be .537 like this.
I rotate the crankshaft until the cam lobe pushes the lifter all the way up to max. travel then back down. All I get is .358. This is a custom ground TPIS ZZX cam that is billet steel and on a small base circle. Wasn't a cheap cam. What gives?
Old Jul 19, 2003 | 06:00 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well it sounds like you're measuring it right. The lobe lift is what it is, it's not something you can change. I believe I'd give TPIS a call if I was you.
Old Jul 19, 2003 | 08:52 AM
Aron213's Avatar
Car: 88 Iroc
Your supposed to use a solid lifter when measuring, are you?
Old Jul 19, 2003 | 09:25 AM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I took a hydraulic one apart and put a flat piece of metal down in it so there will be no movement. I am definitely going to call TPIS. Thanks guys.
Old Jul 19, 2003 | 12:32 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Update:
I went out to the garage today and studied the situation. The dial indicator plunger was getting stuck at one spot causing my readings to be off. This is a weight lifted off my shoulders. Thanks again for the replies.
gta90
Sep 15, 2015 04:00 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
Sanjay
Aug 12, 2015 03:41 PM
Fronzizzle
Aug 9, 2015 01:15 PM
