Knock sensor
Old Oct 15, 2000 | 06:40 PM
merf23's Avatar
Knock sensor
I have an 84 L69 with all the computer stuff removed. I believe the sensor on the lower right side of the block (around cyl #4) is a knock sensor (?) My questions are:
1) Can i wire this to a warning light on the dash?
2) How? Is the sensor an open/close type like a fan switch or is it a variable voltage/resistance switch like a temp gauge sender or O2 sensor.
Old Oct 15, 2000 | 06:43 PM
Blade's Avatar
It's a sensor that spits out variable AC voltage. You would need an electronic circuit to translate that into some sort of bar display. They do make something like that... look in Summit's catalog.
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Old Oct 15, 2000 | 06:48 PM
merf23's Avatar
thanks for the quick answer. Ill check summit. My though is that the sensor can detect much smaller levels of detonation than i can.
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
