Getting hot and don't know why.
Old Oct 13, 2000 | 03:46 PM
chevystud's Avatar
My girl was getting hot and I can't figure out why. I checked the electric fan, it works. I checked all fluid levels, they are fine. Checked for foreign objects blocking air flow to radiator, it's clear. Engine runs great, just gets hot. What else should I check?
91RS, 305, 5-speed, black with pearl white racing stripes. Not that it matters, but K&N airfilter and flowmaster exhaust
Old Oct 13, 2000 | 04:49 PM
ede's Avatar
ede
the t-stat
-=ICON MOTORSPORTS=-
Old Oct 13, 2000 | 09:04 PM
Garmer's Avatar
Chevystud,
My V6 use to run at 220 highway w/ the 195 stat, then when I got my Fastchip I changed to a 160 stat, now I dont even get up to 190!
91 RS Camaro
3.1L
Cat Back System, K&N filter,modified air box, Fastchip Stage 2, 160 thermo, Rapidfires and Bosch Wires, soon to come: Homemade Ram Air,and maybe power pulleys, 5 Air Horns
[This message has been edited by Garmer (edited October 13, 2000).]
Old Oct 14, 2000 | 12:17 AM
theformula's Avatar
Hey chevystud. First replace your thermostat .
If you have $50 laying around order the JET or HYPERTECH fan switch. It makes a WORLD of a difference let me tell you. My car never goes past 200* anymore. Not once! I also put some Red Line watter wetter in there. Works like magic. It's $7 from summit. good luck.
'92 Formula
305 TPI
Mods: SLP catback,SLP air foil,ported plenum,Crane AFPR (49psi),MSD6AL,homemade cold air,K&Ns,3:73s
Old Oct 14, 2000 | 01:21 AM
Dan87IROC-Z's Avatar
Also, your gauage could just be reading incorrectly, how warm does the coolant feel after you shut the car off?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Old Oct 14, 2000 | 12:13 PM
chevystud's Avatar
The AF just spews and bubbles. The gages always have worked good in this car. It could be the therm. I never really thought about that, thanks allot. I'll get back with you and tell you what happens.
Old Oct 15, 2000 | 11:29 PM
Jarod87IROC
Guest
Posts: n/a
Moving to the Tech/General Engine forum.
Old Oct 15, 2000 | 11:49 PM
zroc's Avatar
Car: 87 IROC
Engine: LB9 for the moment
definately check the t-stat... also check the internal condition of the radiator...
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
customblackbird
Aug 15, 2021 10:16 PM
theshackle
Mar 5, 2017 06:37 PM
TheExaminer
Aug 26, 2015 04:59 PM
