Correct Temperature Vacuum switch?
Old Oct 13, 2000 | 11:39 PM
David Trimble's Avatar
In looking into my idling problem I did find that my temperature vacuum switch (TVS) had gone bad on me (it's stuck open even when cold). But when I went to the parts store they asked what color the valve is. The 'cap' on the valve is a green color (and by the way this is not the original switch- this has been in for about 7-8 years), but the store couldn't find a match. Their computer listed 4 colors (I only remember black and blue were 2 of them) but green wasn't one of the choices for that engine. I've got a G-code engine (305 HO). Is the 'green' version of this valve a dealer item, or is it possible that I've been running the wrong valve all this time?
Thanks again in advance for the help!
Original owner - '84 T/A w/stock 305HO 5-speed
Old Oct 14, 2000 | 12:30 AM
Vader's Avatar
DT,
Is this the TVS for the EGR/EVAP purge? Air injection control valve? Thermac?
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Oct 14, 2000 | 11:05 PM
Originally posted by Vader:
DT,
Yes it's for the Evaporative canister purge. Sits to the left of the thermostat housing (if you're facing the engine from the front), has 2 large vacuum connections, black plastic body with a colored top and brass base.
[This message has been edited by David Trimble (edited October 14, 2000).]
Old Oct 16, 2000 | 12:06 AM
Vader- any idea at all?
1992 Trans Am
May 10, 2023 07:19 PM
mdtoren
Aug 23, 2015 12:52 PM
86IROC112
Aug 17, 2015 02:00 PM
mdtoren
Aug 16, 2015 05:45 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
