"how do i prep my motor for storage, need opinions"
Old Oct 15, 2000 | 10:29 PM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
i am storing a 5.0. it only has 25k miles on itand it is on an engine stand and it is goin in my garage. what do u recomend to do it right? note:it does not have an intake on it.
thanx ed
Old Oct 16, 2000 | 07:15 AM
Vader's Avatar
Eddie,
Remove the plugs, fog the cylinders with oil, then hand crank the engine to distribute the oil on the cylinder walls. Drain the oil pan and remove the filter to remove any acidic oil that may have formed while running. Fill with fresh oil if you desire, or tape a note to it warning of an empty sump. Plug all openings, cover the lifter valley with poster board or heavy craft paper. Tape the intake and exhaust ports with 2" duct tape. Slip a plastic trash bag over the entire engine and seal it. If you have some camphor blocks or small dessicant bags, toss a couple in the bage before sealing.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Oct 16, 2000 | 01:03 PM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
thanks
Old Oct 16, 2000 | 01:37 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The Eastwood Company makes these dessicant capsules that screw into your spark plug holes, keeping moisture out of the cylinders. I forget how much they are, they're in their normal catalog but they might be listed on their website too. The website's at http://www.eastwoodcompany.com , they also have a phone # on there if you want to call & ask them.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 16, 2000 | 01:42 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Here, it's at the bottom of this webpage:
http://www.eastwoodco.com/cgi-bin/sg...4315219&FNM=20
Old Oct 16, 2000 | 05:46 PM
Box of Rocks's Avatar
Fast Eddie,
In a word......COSMOLINE.
Actually, just do what Vader said.
BOR
