1.6 rockers on a l03
Old Jul 21, 2003 | 01:30 AM
thehagg
Guest
Posts: n/a
how much of a differance will 1.6 rockers make on my stock lo3 heads? will i have to replace the stocl valvesprings? also is rhere a formula to calculate lift diff?
Old Jul 21, 2003 | 05:00 AM
ede's Avatar
ede
not much to none, the stock springs ought to be wore out by now anyway, bt as far as lift and all they should be fine. really need to know what cam you're running as well as what heads.
Old Jul 21, 2003 | 06:10 AM
thehagg
Guest
Posts: n/a
stock heads and cam from a 89 rs l03
Old Jul 21, 2003 | 07:45 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The change in ratio will make very little difference.
Getting the stock rubber rockers out of there and putting something in that makes the valves follow the cam, may make alot of difference, depending on just how crappy and worn-out your particular rockers are.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
slowsi
Oct 18, 2015 08:49 PM
Jorlain
Oct 8, 2015 01:57 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
anesthes
Sep 21, 2015 10:24 AM
