Slow start srill here
Old Oct 15, 2000 | 01:29 PM
Alberocks's Avatar
My 89 formula 305 TBI is still starting very slow (not until oil pressure has built up to 10psi which tackes some cranking).I have repaced the fuel pump relay and the wireing harness that leads up to the relay. I still have the same problem the ses light is coming up with the code 54 and 32 the 32 Im not to worried about yet. Please help me I dont want to take it to the shop.
Old Oct 16, 2000 | 06:41 PM
Vader's Avatar
Al,
Make sure the relay is operating. You should get about two seconds of pump run when the ignition is first turned on. If that doesn't occur, you need to check the relay, relay wiring, and ECM output to the relay (terminal 'A1' at the ECM).
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
pfsteichen
Feb 9, 2016 06:59 PM
86Base
Aug 8, 2015 01:34 PM
