Running poorly
Old Jul 21, 2003 | 10:59 AM
1991TealRSZZ4's Avatar
Car: 1991 Camaro RS
Engine: ZZ4
Running poorly
My car is powered by a ZZ4 crate engine. I am running an edelbrock 750cfm vacuum secondary carb.
Last weekend I drove to Savannah and back, car was running fine. It pulled good, and didn't have any problems. It sat through a bad storm the next day. Two days later I started the car up, and it sounded a little rough. I let it warm up and drove it down the road. It was hesitating really bad, and bogged down and backfired slightly when I got on it. It doesn't want to idle, and will cut off or idle at a really low rpm (300-400) if I give it gas and let off.
I am ruling out bad gas because I filled up in savannah and drove 170 miles home on the same tank I am on right now, and it drove fine. I pulled the distributor cap and inspected for any water or corrosion, everything checked out ok. I thoroughly inspected all of the spark plug wires and boots, they look ok. I started the car at night and didn't see any arcing from the wires. I pulled all of the plugs and they all looked good.
Does anyone have any ideas on what could've happened, or what is causing my problem? Thanks in advance.
Old Jul 22, 2003 | 10:04 AM
Car: 1991 Camaro RS
Engine: ZZ4
ttt
Old Jul 22, 2003 | 11:45 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Unless you have a Q-jet replacement Edelbrock, or the new AVS series, it's not a vacuum secondary. What model number is it?
Sounds like fuel starvation. Either check the float levels or the float valves to make sure they're working OK.
Do you have a fuel pressure guage? It also sounds like it could be either a fuel filter of fuel pump problem.
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
