Timing mark 34* off, car working perfect!!???Balancer problem? Help!!
Old Jul 21, 2003 | 12:11 PM
socal85tam's Avatar
Car: 1988 IROC-Z
Engine: 383 HSR
Transmission: 4 speed Automatic
Axle/Gears: 4:10
I replaced the harmonic balancer a year ago, cause the old one had the rubber coming off, now that i need to smog it. The car passes all the tests but when the guy checked the timing, it was 34 degrees off,(ATDC) he said that it is imposible for the engine to be that much off, that there has to be some other type of problem with the timing mark, but that I have to fix it in order to pass smog.
Do you have any ideas of what can be wrong?
Do you think that the guys at the autoparts gave the wrong balancer?
Thanks for your time
85 transam, 305 TPI
Old Jul 21, 2003 | 12:17 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's exactly what it is.
You have a balancer that goes with the timing tab at 1:30, but you have the accessory system with the timing tab at 12:30.
Simplest thing to do would be to find TDC accurately, and cut a shallow groove with a hacksaw and fill it with white paint, and fill the stock groove with black (or whatever matches).
Old Jul 21, 2003 | 12:23 PM
jimmy_mac's Avatar
Re: Timing mark 34* off, car working perfect!!???Balancer problem? Help!!
85 transam, 305 TPI
it passes all other tests, but because the stock timing mark and the new balancer are off giving an inacurrate reading they will not pass your car. And they know it's off cause the car runs fine and passes all other test.
The ***** have arrived. It's time to take up arms.
Old Jul 21, 2003 | 12:35 PM
socal85tam's Avatar
Car: 1988 IROC-Z
Engine: 383 HSR
Axle/Gears: 4:10
Does that mean that my actual TDC is at 30* on this balancer? an hour off?
Old Jul 21, 2003 | 01:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
About that....
Ghettobird52
Jul 5, 2024 11:18 PM
midge54
Dec 27, 2019 04:14 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
TheExaminer
Aug 26, 2015 04:59 PM
Thirim
Aug 9, 2015 06:19 PM
