Need Help fast with IAC adjustment!!!!
Subscribe
Oct 16, 2000 | 07:01 PM
I am following the tech article from the board for adjusting idle and IAC but I am having a problem. The car will not stay running after I have disconnected the IAC. I have followed steps to that point but the car will not run or idle.
Need help, what is wrong??????
Reply 0
Oct 16, 2000 | 07:17 PM
Anybody out there??
Reply 0
Oct 16, 2000 | 07:41 PM
come on guys
Reply 0
Oct 16, 2000 | 07:51 PM
I had that same problem and i found my timing was severely retarded. Before I knew the timing was the culprit, I just used a stick to keep the gas pedal slightly depressed so the engine would idle while I adjusted the IAC. Once I set the base timing to 8*, the engine idled fine on its own with the IAC motor disconnected at OPERATING TEMPERATURE. You need to get the motor upto operating temp before making this adjustment. Go drive around for 5-10 mins and then set the IAC and TPS. Should work.
Alternative scenario - check whether your IAC motor works in the first place. My car had this problem, and the previous owner had screwed up IAC adjustement so far as to set an SES light. It wouldn't idle when could and idle at 1500rpm when hot. A simple change of the IAC motor and readjusted minimum air and TPS brought everything back to spec.
'88 IROC 305 TPI
Gutted airboxes
160 degree T-stat
Advanced base TPS voltage
Relocated IAT sensor
Momo steering wheel
Ram-air setup coming soon
Flowmaster muffler
Taylor SpiroPro wires
Accel cap and rotor
Reply 0
Oct 16, 2000 | 07:53 PM
I am trying to make adjustments when teh car is cold, that is probably my problem.
Reply 0
Subscribe
