Uneven acceleration from 89' IROC
Old Jul 21, 2003 | 06:34 PM
NickyCamaro's Avatar
I have an 89'IROC with a tpi 350 motor. It has edelbrock aluminum heads, headers, and I installed a Crane Cams Powermax 2031 recently. The lift is In.438"/Ex.452" and In208/Ex214. When the engine is cold or after it has sat for 20min it runs nice. But after if has been run for ten minutes or so it develops a strange jerky and slow acceleration. At first I though I was setting off the knock sensor but even when the fuel pressure is up to 60psi it still does it. I noticed this problem before but it was never this bad. I tried the timing at 6 and 8 degrees but there was no difference. When I reinstalled the distributor I was in a rush to get it back together so I wasn't very technical about how the rotor was pointing to the no. 1 piston. Could this be the cause?
Prodigious
Nov 7, 2020 09:23 AM
Prodigious
Oct 4, 2015 11:20 PM
BewleyBizzIROC
Sep 7, 2015 08:05 PM
someone972
Aug 30, 2015 12:52 AM
mustangman65_79
Aug 11, 2015 03:17 PM
