When to change brake and power steering fluid
Old Jul 21, 2003 | 10:58 PM
joshwilson3's Avatar
Old Jul 22, 2003 | 04:59 AM
ede's Avatar
ede
never is the interval most people use. it'd be easy to flush out and change brake fluid with a pheniox injector kit. i use synthetic brake fluid, not to be confused with silicone brake fluid.
Old Jul 22, 2003 | 05:21 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Frigging computer problems.
Snap-On makes this cool tool for flushing the brake fluid. It uses a compressor and sucks the fluid out each bleeder at the same time filling the reservoir. I believe the change interval for brake fluid is every 3 years.
I'm not sure on the PS system. I generally flush it whenever I have to replace something in the system. To do that I disconnect the low pressure line, have it run into a catch can, start the engine, and fill the reservoir like mad so it doesn't run dry.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
