glowing catalytic converter
Old Jul 21, 2003 | 11:04 PM
russkull84's Avatar
Car: blue 84 z28
Engine: mildly modified 350
I recently took my 84 carbureted 350 z28 out for a spin and it was running like total crap but I figured it was because it sat for about 2 months. But, after a while it started running worse and worse until finally I had to peddle it just to keep it going. A friend who was following us informed us that the cat was glowing red hot. Of course I stopped and had the thing towed home. What would cause this? The timing has not been messed with and it ran perfectly before it was parked. No vacuum leaks and distributor hasnt moved. What gives?
Old Jul 21, 2003 | 11:36 PM
EvilCartman's Avatar
Car: '82 Z28
It's plugged up, get a new one put on or gut it for the time being.
Old Jul 22, 2003 | 05:36 PM
russkull84's Avatar
Car: blue 84 z28
but the cat is brand new...less than 10,000 miles on it! Its a catco. Could that still be the problem?
Old Jul 22, 2003 | 05:40 PM
mastrdrver's Avatar
If it is glowing red, then you are running way too lean. I would make it richer and see if that fixes the problem, but if it doesnt, then you probably have a plug cat. It doesnt take much when you run the motor too lean
Old Jul 22, 2003 | 05:43 PM
RJR99SS's Avatar
if it was running lean enough to make the cat glow red....i'd think it would melt the exhaust manifolds.
i really think the cat is clogged. But since you say it was sitting, theres a possibility some kind of animal crawled up the exhaust and made a nest, plugging things up.
Old Jul 23, 2003 | 08:30 AM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
Just to be sure, gut the lousy cat. Or, better yet put a strait pipe in for $10 like I did. THen you know for certain if it is the cat or not.
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
okfoz
Oct 13, 2015 02:19 PM
loud91rs
Oct 5, 2015 10:05 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
