approx machine shop costs?
Old Jul 23, 2003 | 09:51 AM
jon_volk's Avatar
just wanted to see what some of you have paid for machine shop labor.....
boring to .040 and finish hone w/ torque plate.
clean/install cam bearings
resize connecting rod big ends (8)
balance rods
balance crank
Old Jul 23, 2003 | 10:17 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Best bet is to call shops in your area, labor rates vary so much across the country.
Old Jul 23, 2003 | 11:10 AM
Vader's Avatar
Mike is absolutely correct. Rates will vary widely across regions, and even from shop to shop.
Rates can vary even within the same shop. I usually get to know the guys in the shop a little. I usually use the shop entrance, and speak directly with the machinists. I try to bring in clean parts that are stripped so that they don't have a lot of tedious screwing around to do. Highlighting the areas to be worked with DyKem also helps avoid questions. I generally tell them to take their time, and use it as fill-in work if necessary, then ask tehm to call me if there are any questions or when it's finished.
I've found that they get done in about the same amount of time, with usually a little more care taken, and at a reduced cost. It also has helped to pick up the parts at the shop entrance instead of the front desk, then ask the machinist who I should pay or to whom the check should be written. When the payee on the check isn't the same name as the business, it's amazing how much lower the rates can be.
Old Jul 23, 2003 | 12:11 PM
Dirty Rob's Avatar
And tax free!
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
sandman92084
Sep 12, 2015 10:27 PM
Fionnla
Wheels and Tires
Sep 11, 2015 11:07 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
89-S-dime
Sep 4, 2015 10:34 AM
