SLP headers and fan turn on switch.
Old Oct 18, 2000 | 11:38 AM
Scott C's Avatar
After installing my new 350 with SLP 1-5/8" headers, I've noticed that I cant hook up the connector to the fan turn on switch in the passenger side head. The connector will constantly be in contact with the header tube, which can't be good. Has anyone had this problem and if so, what did you do? I'm thinking about just running the fan as soon as the ignition turns on by grounding the fan turn on relay. Is there another option?
BTW: The SLP headers were a breeze to install. They dropped in in less than 30 seconds each side. Of course this is with no harness, brackets, or other crap in the way. The y-pipe went on almost as easy. I installed it by myself in about 1 hour. It fits very well. Plenty of clearance at every possible contact point.
Anyway, about that fan switch connector......
'92 RS, ZZ4 10:1 350, Edelbrock 6085 heads, Crane 208/214 467/482 cam, GM/LT4 1.6 true roller rockers, Holley Projection TBI intake, Holley 670 TBI, SLP/Jet-Hot 1-5/8" headers, Catco 3" cat, Flowmaster 3" catback, Hughes 2500 stall converter, stock 700R4, Auburn Pro posi w/3.42, 17x9" SS rims w/BFG tires, Medium Quasar Blue w/white SS stripes, 48,000 miles....
Old Oct 18, 2000 | 04:06 PM
ede's Avatar
ede
i just rerouted the wire away from the headers. i had to add a piece of wire to get the length i needed.
-=ICON MOTORSPORTS=-
1992 Trans Am
May 10, 2023 07:19 PM
RazorN8
Jan 7, 2022 11:44 AM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
Fronzizzle
Aug 9, 2015 01:15 PM
