Whistling `88 Iroc?
Old Jul 24, 2003 | 05:44 PM
cubfanbudman's Avatar
Car: 1988 Iroc-Sold
Engine: LB9 305
Whistling `88 Iroc?
I have a loud whistle coming from my TPI at idle. I relpaced the IAC valve but that didn't help. I went back and cleaned out the seat for the valve better, and it still is whistling. The new valve has a pintle that is shorter than the old one. Should I just clean the old one and put it back in. It also is idling higher than I think it should, around 1200. It is a 5-speed. Ihave only have had the car for a week so I don't know the maintenance that it has had. Any suggestions?
Old Jul 24, 2003 | 07:25 PM
Car: 1988 Iroc-Sold
Engine: LB9 305
Well I put the old IAC in and it idles better, but still whistles. Do I need to reset the computer?
Old Jul 24, 2003 | 07:48 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
check the egr valve? check all your vacuum lines over...
i forgot to put the egr valve back on my 84 z28, and when it started, it whistled really bad.
Old Jul 26, 2003 | 12:27 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Does the whistle go Wooh-Wooh!! Maybe someone snuck a whistle tip on there without your knowledge. LOL
Check for vacuum leaks.
Old Jul 26, 2003 | 10:35 AM
Car: 1988 Iroc-Sold
Engine: LB9 305
I think the previous owner was Bubb Rubb-WOOO WOOO. LOL
Old Jul 26, 2003 | 12:05 PM
Car: 1988 Iroc-Sold
Engine: LB9 305
Fixed
It was leaking by the base of the Throttle Body. Just tightened it up.
theshackle
Sep 17, 2020 08:26 AM
BAMiller
Sep 14, 2015 06:38 PM
angel2794
Sep 8, 2015 06:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
